Fan Tray 2 for 6500 (non-E model)
Answered Question
Sep 10th, 2007
Hi All,
In order to support 10GB link for 6500 non-E module, Fan Tray 2 need to be installed. Does the "Fan Tray 2" means the high speed fan tray? and also 2500W power supply or up needed to support the "Fan Tray 2?"
Thank you!
Best Regards,
Teru Lei
Correct Answer by Jon Marshall about 9 years 10 months ago
Yes you need the non-E high speed fan tray and the part number is:
WS-C6K-9SLOT-FAN2
Yes you will need to upgrade the power supply to at least 2500W.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Mon, 09/10/2007 - 00:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
WS-C6K-9SLOT-FAN2
Jon
p-blake Sat, 11/10/2007 - 15:08
How can one tell if they have the high speed fan tray, fan2 installed?
Is there a command?
Thanks..
Jon Marshall Sat, 11/10/2007 - 17:19
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
"sh env cooling" should show you the fan part number.
Jon
p-blake Sun, 11/11/2007 - 10:39
I don't have that option. I am running CatOS. I have a show env temp but it doesn't show any part numbers. Any other suggestions.
Thanks for your help.
Paul
