UK Emergency 999 route immediately
Answered Question
Sep 10th, 2007
  • Silver, 250 points or more
Is there any solution to route '999' without having to rely on interdigit timeout. Essentially I would like to route 999 immediately since my dialplan will exlude '99' as leading digits completely.
tia
Ajaz
Correct Answer by Rob Huffman about 9 years 9 months ago
Hi Ajaz,
Have you tried the "urgent priority" check box on the 999 route pattern that immediately matches the pattern and routes the call without waiting for more digits.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Mon, 09/10/2007 - 04:14
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ajaz,
Hope this helps!
Rob
AJAZ NAWAZ Mon, 09/10/2007 - 04:54
that did it!
Thanks Rob
Ajaz :-)
Rob Huffman Mon, 09/10/2007 - 05:31
  • Hall of Fame,
    Founding Member
Hi Ajaz,
You are most welcome my friend :)
Take care,
Rob
