09-10-2007 02:49 AM - edited 03-14-2019 11:27 PM
In a centralized standard corporate model how many CSS's are typically used per site, and how many partitions per-site?
is there any particular rule or naming convention one should be following?
tia
Ajaz
Solved! Go to Solution.
09-10-2007 04:51 AM
Hi Ajaz,
I'm not sure that there is a typical number of CSS's as this depends on the requirements and level of restrictions one may need. There are some really thoughtful "Best Practice" design ideas below;
"Use concise and descriptive names for your partitions. The CompanynameLocationCalltype format usually provides a sufficient level of detail and is short enough to enable you to quickly and easily identify a partition. For example, CiscoDallasMetroPT identifies a partition for toll-free, inter-local access and transport area (LATA) calls from the Cisco office in Dallas."
And for CSS;
The CompanynameLocationCalltype format usually provides a sufficient level of detail and is short enough to enable you to quickly and easily identify a calling search space. For example, CiscoDallasMetroCS identifies a calling search space for toll-free, inter-local access and transport area (LATA) calls from the Cisco office in Dallas.
From this doc;
Partition Configuration Settings
There are some nice ideas in this doc;
Understanding and Using Partitions and Calling Search Spaces with Cisco CallManager
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094b53.shtml
And this interactive link;
Voice Dial Plan Interactive Voice Network Configuration Example
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00807f54af.shtml
Hope this helps!
Rob
09-10-2007 04:51 AM
Hi Ajaz,
And for CSS;
From this doc;
Hope this helps!
Rob
09-12-2007 02:07 AM
Really appreciate that.
Ajaz
09-12-2007 04:59 AM
Hi Ajaz,
You are most welcome my friend :)
Take care,
Rob
