Sep 10th, 2007
I have a publisher replication issue on my CCM Cluster.
Running the DB Helper file did not fix the replication issue
Firstly I tried the ?Reinitialize? button on the DB Helper utility and this did not work and then later I tried the ?Republish? button on the DB Helper Utility.
Either of the functions did not work and the replication issue is still present.
Another strange thing is that, In the SQL enterprise manager, I can only see the Publisher Listed (as Local) I cant see any of my 3 subcribers in the under Micsrosoft SQL servers. Attached are the error log files that I have.
Please advise on next steps
