4500 dual supervisor second sup disabled?
Answered Question
Sep 10th, 2007
  • Silver, 250 points or more
A colleague has just called me, so things are a little hazy just yet. He has a 4500 switch with dual sup, and on one switch if he does a sh mod it shows the second sup as disabled - any ideas why that may be the case?
Thanks.
Correct Answer by Edison Ortiz about 9 years 10 months ago
The secondary Supervisor can be in rommon mode.
Have your colleague plug a console cable on this Supervisor to verify its status.
Overall Rating: 3.7 (3 ratings)
Martin Parry Mon, 09/10/2007 - 07:27
Is the 4500 an R eg: is it a 4507R or 4510R? If you have placed it in a 4506 for instance the secondary supervisor will not be supported?
jcoke@afsimage.com Mon, 09/10/2007 - 15:15
The cat4.5k supervisors are keyed and cannot be (fully) inserted into non-supervisor slots, which is what slot >1 would be in a non-R chassis. Same goes for line cards in sup slots.
To the OP: I would start by looking at the console messages when the supervisor is first inserted, making sure blinky lights happen etc. Also use the "sh diag" commands to see if the thing failed a post test or something.
Correct Answer
Edison Ortiz Mon, 09/10/2007 - 19:22
  • Hall of Fame,
    Founding Member
paul.matthews Mon, 09/17/2007 - 02:14
Bingo - that's the one - now told to boot and all OK.
Many thanks for all the suggestions,
Paul.
Jacob-Harris Mon, 09/17/2007 - 09:47
Paul,
May be a good idea to check the conf reg also to ensure the sup will auto boot if it runs into issues again. Had that problem, one of my intern techs through in a rommon conf reg and it caused a similiar status.
paul.matthews Mon, 09/17/2007 - 23:30
Don't worry - I am going to get my colleague to check it...
Paul
nmg-craft Wed, 09/19/2007 - 14:12
hello all,
I have a similar query with dual supervisor engines (4507Rs +sup iv)
is it necessary to have same ios version on both of them for sso redundancy ?
Next is ...
I have 2 uplinks configured on the first one..but when i inserted the second sup, the second uplink from first sup (gi 1/2) was not coming up. But it automatically takes gi 2/1 port on the second sup as the second uplink..is this is a normal behaviour...?
please help...
Edison Ortiz Wed, 09/19/2007 - 14:54
  • Hall of Fame,
    Founding Member
Yes, you need same IOS on both.
Yes, the second port is disabled on the dual-sup hardware.
