09-10-2007 05:52 AM
I am trying out the Multiple Privilege Level option on a directly connected router - but I cannot get it to work.
This configuration example is not possible...
enable secret level xxx
enable secret xxx
privilege configure level 6 hostname
line con 0
line aux 0
line vty 0 4
When I log directly in I get...
Router>en 6
Password:
Router#conf t
% Invalid input detected at '^' marker.
Why can't I change just the hostname on the router using the Privilege level 6 ???
This should be simple but I miss something.
09-14-2007 06:12 AM
You must allow access for Gloabal configuration command to a previlege level to configure the host name as host names can be configured only if you have access to global configuration command. Use the command Router(config)# privilege exec level 6 configure terminal
09-20-2007 12:38 AM
Here you will find a configuration example:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080112495.html
Maybe it is of any use to you!
Michael
