CWLMS 2.6: Can't find applicable devie package for X.X.X.X
Sep 10th, 2007
I am using CWLMS 2.6, but after discovery i can find that Cisco View for 2960 series switch is not available.
It is suggesting for device package installation.
Please suggest.
Rgds..Partha Acharya
Joe Clarke Mon, 09/10/2007 - 09:33
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Go to Common Services > Software Center > Device Update, select CiscoView, and select the updated device packages for your device. For best results, you should choose all available device package updates that are available.
acharyr123 Mon, 09/10/2007 - 20:30
Hi, Thanks for your reply. But whenever i try to do so it asks for CCO login & password. I am putting my login credentials but it says invalid cco id & password. But using this same credential i am able to login to cisco, download IOS & other softwares.
Please suggest...
Joe Clarke Mon, 09/10/2007 - 20:41
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Do you need a proxy to connect to Cisco.com? If so, have you configured those settings correctly in LMS?
acharyr123 Mon, 09/10/2007 - 21:50
Yes, i do need to authenticate via proxy & the setting is done in CWLMS
