AAA Upgrade
Sep 10th, 2007
Can I directly upgrade my AAA 3.3 to 4.1? Do I need any extra patch?
Jagdeep Gambhir Mon, 09/10/2007 - 07:12
You can upgrade 3.3.3 or directly to 4.1.
Supported Migration Path for ACS.
ACS has tested and supports the migration path from:
?ACS 3.2.3 to ACS 3.3.3 to ACS 4.1.
?ACS 3.3.3 to ACS 4.1.
No other patch needed.
Please rate if helps
abbas.wasim Mon, 09/10/2007 - 07:24
May I know if I've the migration disk can I just use it without need of buying any more licence, e.g. is the migration is free of charge?
Jagdeep Gambhir Mon, 09/10/2007 - 07:38
Upgrade from acs 3.3 to 4.x is a major upgrade, so you need to purchase it.
jhillend Mon, 09/10/2007 - 09:06
Please note that there is a 4.1.4 update that you should apply. It provides some new features and is also a cumulative patch update. You need to upgrade to 4.1.1 first, have a support contract for 4.1 and get the TAC to publish the update for you.
