Need Lab Access for CCNP
Sep 10th, 2007
hey i am trying to apply for my CCNP certification and i need some home lab simulator or some one how provide me a rack for some nominal charges so i can practice my ccnp lab. is any body help me who knows the right source for the lab practice ?
Rakesh Patel
mark.j.hodge Wed, 09/12/2007 - 04:50
If you have access to the necessary IOS images then there is a free simulator which is very good. It runs OK under windows, but performance is better under Linux on the same hardware.
Dynamips is the simulator
http://www.ipflow.utc.fr/index.php/Cisco_7200_Simulator
And there is a front end which makes configuration easier
http://dynagen.org/
** please rate posts if helpfull **
alaishandre Mon, 09/17/2007 - 03:24
Mr. Hodge,
Is it possible to use IOS images other than the 7200 IOS image for dynamips?
fred.mancen Mon, 09/17/2007 - 05:25
Yes my friend, you can use the 3620, 3640 and 3660; 2691, 3725, 3745, 7204 (NPE-100 to NPE-400) and 7206VXR with NPE-200. It is a useful tool, that provides real resources and helps a lot to a certification training.
Regards.
cyphur353 Mon, 09/17/2007 - 05:27
Look into Dynagen(www.dynagen.org), it makes managing and configuring Dynamips a breeze. They have a tutorial that explains how to use other devices/IOS's other than just the 7200. It's basically just changing the model statement, and updating the IOS path.
suelange Tue, 09/18/2007 - 07:05
I have used both Dynagen and TheBryantAdvantage. Dynagen is great place to start, assuming you have in your mind some exercises to try and/or a book to guide you. BUT you do have to own a router under maintenance in order to get an image to work with.
The benefit to BA is that you get his materials plus 3 days of lab time. His labs are awesome, they give you lots of detail. I found I could complete them in about 1 day, review them another day then still have 1 day lab time to try stuff that I found confusing during various reading sessions.
Good luck!
