VACL Question
Sep 10th, 2007
Can someone please explain what the 10 represent on the access-map? If this is the vlan maping, i don't have vlan 10.
vlan access-map RSPAN-VACL 10
match ip address TCP_Connection
action forward
vlan filter RSPAN-VACL vlan-list 999
Steve
Overall Rating: 5 (2 ratings)
Martin Parry Mon, 09/10/2007 - 07:44
  • Silver, 250 points or more
The 10 is the sequence number. it allows you to specify differen't criteria within your access-map. For instance you may want to specify another set of criteria under sequence number 10.
Martin Parry Mon, 09/10/2007 - 07:46
Sorry that didn't make any sense.
You may be matching certain criteria within sequence number 10, then you may match against other criteria sequence 20.
