Full mesh of GRE over IPSEC tunnels
Dear All,
We have around 10 different locations and there is a full mesh connectivity between them, now I need to encrypt the traffic between these sites, now if i create a static tunnel between each locations then it will not be scalable so how can i achieve this, can i achive this by mGRE and DMVPN, but again this works fine in case of hub and spoke environment but in any to any kind of a scenario will it be useful.
Please help.
a.alekseev
Level 7
Level 7
rcsmith
OSPF
interface Tunnel0
bandwidth 3938
ip address mask
ip mtu 1416
ip nhrp authentication
!one pair per remote router
ip nhrp map multicast
ip nhrp map
ip nhrp network-id
ip ospf network point-to-multipoint
ip ospf priority 0
ip ospf 1 area 0.0.0.0
delay 20
tunnel source Loopback10
tunnel mode gre multipoint
tunnel key
tunnel protection ipsec profile
router ospf 1
router-id
log-adjacency-changes
EIGRP
interface Tunnel0
bandwidth 128
ip address mask
ip mtu 1416
ip hello-interval eigrp 1 15
ip hold-time eigrp 1 45
ip nhrp map
ip nhrp network-id
tunnel key
router eigrp 1
network
network
no auto-summary
Not sure I actually posted this yesterday?
But the EIGRP configuration has been used for over three years and works well, note the EIGRP timers pushed out to what you see, it was because the defaults are too sensitive.
The OSPF is proving somewhat irksome; there are lots of OSPF adj changes in the logs, even with the timers adjusted.
