Can I copy 1200 wireless configuration to 1300
chicagotech
I have 10 1200 wireless AP running. I just bought 3 1300 wireless bridge. They will do the same as 1200. Here is the configuration just in a case you like to check it: Sample of Cisco 1200 Access Point
http://www.howtonetworking.com/cisco/1200apsample.htm
I can copy the configuration of 1200 to 1300?
jcartier
Most of the commands should take. But since I am unsure of the IOS versions you may have one or two commands that are unaccepted by the 1300.
All in all...it should take and be operational to the 1200's spec.
jcartier
