Management VLAN up
Answered Question
Sep 10th, 2007
How do I keep the management VLAN up without any device connected?
Do I need a loopback interface?
I'm using a Catalyst 3560 switch.
Thanks in advance.
Correct Answer by Richard Burts about 9 years 4 months ago
Andres
To keep a VLAN active it should have at least 1 port connected to a device or should have an active trunk. You have not given us any information about what the 3560 connects to. Is it possible to configure a port on the 3560 as a trunk and include the VLAN in the trunk?
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Mon, 09/10/2007 - 11:27
Andres
Rick
andresmardones Mon, 09/10/2007 - 11:41
Rick,
I understand, it is clear. Yes, it is possible to include the management VLAN in a trunk.
Many thanks Rick!
Regards.
Andres.
