easy vpn client/server problem
Sep 10th, 2007
hi
i have setup a small easy vpn client/server network with a pix 515 as the server
and a pix 501 as the client
on the easy vpn server i have configured it to require user-authentication
what i need to know is this what address do i have to type into my browser address bar to
access the remote vpn client interactive login page directly,if i access the interactive login
page via a redirect message the address i end up with is https://192.168.1.1/vpnclient/loginuser.html
but if i type this address in myself i end up with a HTTP 404 - File not found error message
any help will be appreciated
regards
Melvyn Brown
amritpatek Fri, 09/14/2007 - 12:57
The link has to be redirected to the login page and cannot be accessed directly because when the link is redirected you are already connected to the remote host, however in the second case when you maually input the address you are were not previously connected and hence the browser dispalys the error message.
