cisco 3002 hardware client problem
Sep 10th, 2007
hi
i have setup a small easy vpn client/server network with a pix 515 as the server and a cisco
3002 hardware client as the client i have set the server to require user-authentication but
i am having problems what happens is this after i establish the tunnel i go to the login page on
the hardware client and enter the credentials in this case its username fred and the password
is flintstone the reply i get back is.
Connection/Login Error
Authentication Error:No Active server found
i have no idea what server the Authentication Error is referring to as the username/password
is configured on the easy vpn server
i've included the easy vpn server config as an attachment would be grateful if someone could take a look
and advise me where the problem lies
regards
Melvyn Brown
ps i tried setting up a csacs server and put the username/password on there
but it made no difference, if i disable user-authentication everything works fine.
tstanik Fri, 09/14/2007 - 13:00
  • Bronze, 100 points or more
You should configure an external authentication server and make the easy VPN server to check for the authentication request from this external server. The authentication server and the easy vpn server should be at the same location. Also check for the authentication request sent by the client to the server.
