How to setup 805 for using with Cablemodem for Internet and Serial Modem
acme-leon
I have two regional offices connected Via serial Modem on a clear channel, in the main office I need to setup the internet conection in order to works simultaneously with the corporate conection. The corporate is Using the clear channel via serial port ppp with the 192.168.1.103 as gateway. The cablemodem is motorola and it uses a public IP, How do I configure the router??
spremkumar
Level 9
Level 9
hi
afaik i dont think your 805 will be able to accomodate 3 connections as per your requirement here (Serial link/LAN/Internet).
you need to go for an upgrade so that you can accomodate all the three connecitvities onto a single box.
I would suggest to check out for Cisco 1841 series router with Wic-1T card where you can terminate your serial link onto it and 2 fast ethernet ports available for your LAN and for internet connectivity.
regds
