cannot view or modify IOS IPS signatures
Sep 10th, 2007
what could be wrong with my config? i managed update my IOS IPS with the latest signature definition file to S291.0 and i cant seem to see the signatures or even modify them.
part of my config below:
ip ips config location flash:/ipsstore/ retries 1
ip ips notify SDEE
ip ips name sdm_ips_rule
ip ips signature-category
category all
retired true
category ios_ips basic
retired false
crypto key pubkey-chain rsa
named-key realm-cisco.pub
key-string
30820122 300D0609 2A864.....
Overall Rating: 1 (1 ratings)
aghaznavi Fri, 09/14/2007 - 13:00
  • Silver, 250 points or more
After selecting a pretuned SDF file for a router, you can do additional signature tuning tasks. You can add, edit, delete, and modify signatures to best fit your needs, or you can even create your own signatures when necessary. The following gives an example of how to add additional signatures and modify the actions using IPS MC. Select the device or device groups you want to configure, and then go to Settings->Signatures->IOS IPS.
http://www.cisco.com/en/US/products/ps6634/products_white_paper0900aecd8043bc07.shtml
brianbono Fri, 09/14/2007 - 19:46
i cant add, edit, delete or even modify the signatures. kinda weired but i see IPS events happening on the monitor tab.
