FXO Disconnect on H323 and MGCP difference?
Sep 10th, 2007
Is there a difference with regards to supervisory disconnect tone on FXO using H323 gateway and MGCP gateway?
Problem is... Have this setup were supervisory disconnect tone works on MGCP gateway while not working on h323 gateway.
Same telco provider. Recorded and checked the disconnect tone and both same freq and cadence.
Same router platform and ios version.
both H323 and MGCP gateways is connected on the same CCM.
FXO's are used for outgoing calls only.
Setup:
IP phone---ccm5.0.4----3845(ios 12.4(9)T2)-----PSTN.
Configs:
voice class custom-cptone test
dualtone busy
frequency 480 620
cadence 500 500
dualtone disconnect
frequency 480 620
cadence 250 250
voice-port 3/0/1
supervisory disconnect dualtone mid-call
supervisory custom-cptone test
no battery-reversal
timeouts call-disconnect 0
timeouts wait-release 1
timing hookflash-out 50
caller-id enable
Attached is the running config and the disconnect tone recorded in case my interpretation of the freq and cadence is wrong.
Appreciate any help i can get.
Thanks!
sadbulali Fri, 09/14/2007 - 13:32
  • Bronze, 100 points or more
send me the following debugs from the gateway for a failed call.
debug vpm signal
debug mgcp packet
