ops manager and hp nnm integration issue
Answered Question
Sep 10th, 2007
hi all,
can i integrate hp nnm and ciscoworks ops manager just as i can integrate nnm and lms?if there is no available tool,is there any way to integrate them?thanks in advance.
Correct Answer by Joe Clarke about 9 years 8 months ago
No, there are no CUOM launch points installed. If you integrate LMS with NNM, you will get CiscoView and Device Center launch points within NNM.
Overall Rating: 5 (2 ratings)
Joe Clarke Mon, 09/10/2007 - 21:46
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
While you can integrate the symbols, traps, etc. into NNM, there are no integration launch points back into CUOM by default.
thetnaing00 Mon, 09/10/2007 - 22:22
hi joe,
thanks.so i cannot launch the ops manager by clicking the icons in HP NNM,am i right?
the other thing is can i use integration tool 1.6 to integrate lms 2.6 with nnm 7.5? thanks
Correct Answer
Joe Clarke Mon, 09/10/2007 - 22:30
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
