CUE editor Dial by extension without Terminating Key
Sep 11th, 2007
I created an script with dial by extension (option 0 in menu). When you dial the extension(three digits: 3xx) after 0 i must dial #. I tried delete # key but when I did it Script doesn't work. The input length was changed to 3 but it did the same and no transfer unless you press # although I write in Terminating Key=none.
I reload and overwrite the script againg but I don't get it.
Thanks in advance
Markus Schneider Tue, 09/11/2007 - 05:59
  • Cisco Employee,
What is your Input Length? If you have Terminating Key=none, and Input Length=10 (for example), then it will only go to the Successful branch if 10 digits are entered. If you put Input Length=3, then it will collect exactly 3 digits.
