09-11-2007 01:03 AM - edited 03-11-2019 04:09 AM
Hi ,
I have a query.I have hosted a server in the Inside zone of the ASA firewall.Whenever i try to access the url from inside i find the packet getting blocked by the firewall throwing an error "UDP flooding".After which i added a proxy and then when accessed the same was working fine.Can i not achieve the requirement without adding a proxy.I am sure there should be some command in ASA which should help me avoid UDP flooding when accessing the url from inside.Kindly suggest.
Jkannan
09-11-2007 08:00 AM
I would suggest you look at the rules governing access from the inside to the DMZ and vice versa. What you have stated suggests that the proxy is allowed through but the other machine is not.
09-20-2007 03:29 AM
There is no dmz in this case.The firewall is enabled for only Inside to Outside Internet access and also is configured for port forwaring features to access certain servers from outside. Am sure there should be some cli based command to stop the udp flooding.Please help..
regards..Jkannan
10-07-2007 10:41 PM
Hi ,
Kindly suggest on the above.
Is this a problem because of the sysopt noproxyarp functionality.The output of the present show run sysopt is as mentioned below.
Should i apply no sysopt nopproxyarp outside command, so that the inside users can access the webserver hosted in the inside using the url directly.
# show run sysopt
no sysopt connection timewait
sysopt connection tcpmss 1380
sysopt connection tcpmss minimum 0
no sysopt nodnsalias inbound
no sysopt nodnsalias outbound
no sysopt radius ignore-secret
sysopt connection permit-vpn
regards...Jkannan
