Output packets dropped
Sep 11th, 2007
Can you explain why I'm receiving excessive output drops on the following interface and what can be done to resolve it.
gh5-c4506-2#sh int port-channel 16
Port-channel16 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 000f.2386.e328 (bia 000f.2386.e328)
Description: .... Etherchannel for unix server rack
MTU 1500 bytes, BW 4000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is N/A
input flow-control is off, output flow-control is unsupported
Members in this channel: Gi5/41 Gi5/42 Gi5/43 Gi5/44
Last input 5d15h, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 97166753
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 4341000 bits/sec, 540 packets/sec
5 minute output rate 1287000 bits/sec, 417 packets/sec
246065750 packets input, 348619887609 bytes, 0 no buffer
Received 116910 broadcasts (98024 multicast)
527460 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
718036014 packets output, 889508674274 bytes, 0 underruns
0 lost carrier, 0 no carrier
gh5-c4506-2#
amritpatek Mon, 09/17/2007 - 06:28
  • Silver, 250 points or more
You may get output drops because of bursty traffic. In such a case you can increase the size of the output queue and also monitor the CPU and memory usage. If the issue is not with bursty traffic check for the speed and duplex settings of the link. If speed and duplex settings are fine I would suggest that you try and implement some etherchannel load balancing over this link to help compensate for the traffic that is filling up your output queue buffer on these ports. I would also suggest that you try implementing flow control to see if this helps to alleviate the issue.
mell0ns23 Mon, 09/17/2007 - 07:31
Thanks for the feedback Amritpatek. I'll take your suggestions into consideration.
