Cisco 2811 voice bundled router configuration
Sep 11th, 2007
I have 2 cisco 2811 routers with voice bundle. My problem is i have two networks, 1 with 192.168.100.???, 2 with 192.168.200.???. I need these both networks should be interconnected and internet also should be flown in these networks. Kindly help me in what gateway i should maintain . If you need more info on this, i can provide.
Pavan
spremkumar Tue, 09/11/2007 - 02:45
  • Red, 2250 points or more
hi pavan
if you are planning to use only one ethernet interface you can have multiple secondary addresses configured under your ethernet interface which can be set as gatway for your networks.
for internet access you need to create 2 different two different nat statements either with overload or static nat statement.
regds
