Routing issue
Answered Question
Sep 11th, 2007
Good day,
VPN Client issue here. User authenticates agains the firewall(gets IP from a pool) and can access everything fine and dandy on the directly connected lan. He goes to access a lan in another building that but cant.
the lan in the other building is connected by a 100mb lan extension so it has a router on the other side.
The router on that side has a route back to the ip pool that is used for the remote users. Weird thing is from router in the network he can not reach I can ping the ip he has been assigned from the pool.
when I look at the live logs via asdm i filter for his IP but can not see any traffic coming in from him to the network he is trying to reach.
when he does a traceroute to the network directly connected it gets there in one hop however when he does a traceroute the network that isnt working it tries to go out over various gateways on the internet.
i should point out Im relativly new to PIX but the fact that from the network the user cant access I can succesfully ping the remote user but not vice versa suggest that routing is OK??
Please help!
Correct Answer by Anthony Holloway about 9 years 6 months ago
It should. Only I wouls switch those ACEs to standard instead of extended.
access-list 101 standard permit 10.50.20.0 255.255.255.0
Overall Rating: 5 (1 ratings)
a.alekseev Tue, 09/11/2007 - 04:12
  • Gold, 750 points or more
Check split-tinneling access-list.
Is the lan in another building included in the ACL?
darkbeatzz Tue, 09/11/2007 - 04:33
thanks for the reply.
how can I check the spit tunneling acl
normal users on both networks have problems connecting to each other its just the remote client vpn users
sadcock123 Tue, 09/11/2007 - 06:17
Try putting a route on your PIX firewall for the network that is not directly connected to the router.
For example:-
PIX connected LAN is 10.0.0.0/24 - Router network is 10.0.1.0/24. The router has a connected interface into the 10.0.0.0/24 and sends out of Eth1 for example and connected to eth1 is the 10.0.0.0/24 hence it works. The Client pool is 192.168.1.0/24. You also have a route on the router for 192.168.1.0/24 to go out of eth1. You need a route on the PIX anything for 10.0.1.0/24 go to Eth1 Ip address on the Router.
If this does not make sence let me know.
Cheers
Steven
darkbeatzz Tue, 09/11/2007 - 07:22
Hi Steven,
Thanks for the reply.
I have a route on the pix already, the weird thing is I can ping the remote vpn client's pool IP address from the lan not directly connected. Could it be something to do with IPSEC rules?
darkbeatzz Tue, 09/11/2007 - 09:40
I have that option configured however I dont see a rule for on the inside interface which would basically say
allow 192.168.10.0 get to 10.50.20.0 IP permit
Although I can ping the vpn client from 10.50.20.0 network it doesnt make sense to me that if i was to add this rule all would be well.
what do you think
Anthony Holloway Tue, 09/11/2007 - 13:59
  • Purple, 4500 points or more
It sounds like your split tunnel is in need of some help.
If you posted your config it would help but I can probably guess what you have/need.
CLI only:
look for a section in your group-policy that specifies the split-tunnel-policy and split-tunnel-network-list value.
set your policy to tunnelspecified and your network-list value to the ACL that defines the split tunnel traffic.
your split tunnel ACL should look something like this:
access-list 101 standard permit 192.168.1.0 255.255.255.0
access-list 101 standard permit 172.16.1.0 255.255.255.0
Where 192.168.1.0/24 is your local LAN that you can access now, and 172.16.1.0/24 is the LAN in the other building.
darkbeatzz Tue, 09/11/2007 - 14:45
I think you might have it there my friend.
here is the config from the CLI. there is not access list for the 10.50.20.0/24 network which the remove vpn client can not get to.
split-tunnel-policy tunnelspecified
split-tunnel-network-list value 100
access-list 100 extended permit ip 160.100.50.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list 100 extended permit ip 160.100.0.0 255.255.0.0 192.168.10.0 255.255.255.0
so tomorrow I will add
access-list 100 extended permit ip 10.50.20.0 255.255.255.0 192.168.10.0
255.255.255.0
which should do the trick yeah?
Correct Answer
Anthony Holloway Tue, 09/11/2007 - 16:36
darkbeatzz Wed, 09/12/2007 - 02:00
your a star that done the job. just had to add a no nat rule aswell
thanks a mill
