carl_townshend Tue, 09/11/2007 - 07:27
but how will it know it can route through the isdn if the other interface goes down, if it gets no updates ?
carl_townshend Wed, 09/12/2007 - 04:37
Can I use the backup interface command with eigrp ? will this stop the updates bringing up the line? or is floating static routes the only option in this case, has anyone got an example config with eigrp ?
many thanks
lgijssel Tue, 09/11/2007 - 11:13
  • Red, 2250 points or more
Carl, after 2239 posts, how much have you learned? Previously you stated that you are educating yourself using this forum. I have nothing against that but meanwhile I have the impression that you are one of those who will never learn anything! For a start, you still haven't learned to rate posts that are helpful to you and that would be the least to do for someone who is using this forum so intensively.
I CANNOT UNDERSTAND THAT THERE ARE STILL PEOPLE THAT ARE WILLING TO ANSWER YOUR SILLY QUESTIONS. I suppose this is solely due to the massive amount of knowledgeable people around that are not yet completely flabbergasted with your stupidity!
Therefore once again, I solemnly ask you to start rating posts; it is the least you can do for those who are still bothering to answer your oneliners. For the rest I wish you all the best, you need it!
Being polite is not always the right approach.
Leo
lgijssel Tue, 09/11/2007 - 11:40
Carl, the solution for this is using floating static routes. Do a search for that on CCO and
you might be able to find it out by yourself.
regards,
Leo
