GRE over Frame relay
Richard Burts Tue, 09/11/2007 - 04:28
Nagesh
I have not done this exactly as you describe so I can not speak from experience. But it should be easy to do.
I believe that any router that supports point to point Frame Relay will also support GRE tunnels. they have been supported in IOS for a very long time.
The configuration would look something like this (details would obviously depend on your situation):
interface tunnel 1
ip address
tunnel source serial1/1.200
tunnel destination
Rick
