any tool to migrate from a Nokia/CheckPoint firewall to CISCO ASA
Answered Question
Sep 11th, 2007
Would like to know if there is any tool that could help to migrate CheckPoint firewall objects and rules database to CISCO ASA equivalent ;
Could the last CISCO Security Manager product help in this process ?
thanks in advance
Correct Answer by swconnexnml about 9 years 5 months ago
Hi Joel, plse check this link:
http://cisco.com/cgi-bin/tablebuild.pl/sct
Cisco Security Conversion Tool
-steve
Overall Rating: 5 (2 ratings)
JORGE RODRIGUEZ Tue, 09/11/2007 - 07:03
Joel, you may need to use a firewall analyser or fw auditing tools to retreave fw rules from Nokia/Fw-1 in a legibel format like using LFA, but you still need to manually entered the configuration into ASA.
Check this link and look for (LFA) Lumeta firewall analyser, they work along with checkpoint..
http://www.lumeta.com/
Also reference this thread, it may help.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Security&topic=General&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1dd7e5c4
Jorge
guillerm Wed, 10/31/2007 - 10:50
Steve,
thanks a lot for your answer ;
I have started to use SCT : this tool is not bad at all ;
it will certainly avoid me some nightmares
Anand Kanani Sun, 01/05/2014 - 01:05
Here is the new self-service tool that Cisco has released to convert to any vendor firewalls to Cisco ASA.
Currently it supports Juniper ScreenOS and CheckPoint to Cisco ASA conversion.
Link to the original post:
https://supportforums.cisco.com/community/netpro/security/firewall/blog/2013/12/19/conversion-tool--checkpoint-fw-to-cisco-asa
Link to the tool itself:
https://fwmig.cisco.com
