09-11-2007 06:16 AM - edited 03-05-2019 06:24 PM
I wanna know what features of cisco 3750 for detecting duplicate ip addresses.let's say I assign 5 IP addresses for my managers by using the dhcp server.If someone(internal users) try to set those ip addresses manually then how do I (prevent/detect) duplicate ip addresses in this case.
What are features of cisco 3750 can do?
please feel free to add any comments
Thot
09-11-2007 07:38 AM
I think the DHCP server will check that an IP address is not in use (by ARPing for it) before it issues it.
Conversely, a statically configured PC will also do an ARP for its own address before it boots up, and if it detects a conflict it will tell the user and not boot. I cannot say what other types of host might do.
If you really want to tie it down, you could make a fixed DHCP mapping, but this can get administratively heavy on a big site.
Kevin Dorrell
Luxembourg
09-11-2007 09:23 AM
Take a look at IP Source Guard. It's one part of a really nice suite of features aimed at layer 2 security. It rides on DHCP snooping which, in and of itself, is useful for blocking rogue DHCP servers.
DHCP Snooping and IP Source Guard on the 3750
You might also consider adding Dynamic ARP Inspection to round out the trio.
