packets not Switched in hardware in 7600
Hi!
I configured 1 VRF in a 7600. I need to send some packets from the global table to that VRF. I configured 2 ports, one in the global table and the other in the VRF and join the 2 ports with a crossover cable. To send the traffic to the VRF i used a PBR. It works but
the traffic switched by de VRF is CEF in software, not in hardare. This configuration is supported in 7600?
Thanks in advance!!!
ybajpai Tue, 09/11/2007 - 12:32
PBR in VRF is not supported on the c7600 yet. I think it is coming soon though. (dont hold me on that though ;-) )
ybajpai Tue, 09/11/2007 - 12:45
can you try removing the pbr and use static routes to push traffic to the vrf instead? see if that changes anything.
No. the customer wants to make PBR. Voice packets are not routed through the VRF.
route-map pr deny 3
match ip address platinum
route-map pr permit 5
match ip address acl-pbr-ADSL
set ip next-hop 1.1.1.10
matching the ACL platinum the traffic follow normal routing. Traffic Matching acl-pbr-ADSL goes through ADSL.
Thanks in advance!!
ybajpai Tue, 09/11/2007 - 13:09
i just checked and it seems like vrf aware pbr is supported in the latest SRB1 release on advanced feature set images.
If you have an IP services IOS image then it will be software switched and this is a known limitation because those featuret dont mave the necessary mpls makefiles complied in the code.
ensure that ur customer is running advanced ios and srb1 code to support hardware switching of pbr packets pushed in the vrf.
