TACACS+ and SecurID for ADSM
Sep 11th, 2007
Is it possible to use tacacs+,securID and adsm? I'm using it and it works OK for ssh. When using https and adsm I get prompted for my username frequently during a session. I'm using pix software 7.1(2) and acs3.3. I don't want to have to configure local passwords for admin access. THX
Overall Rating: 5 (1 ratings)
rochopra Tue, 09/11/2007 - 09:51
secureID will not work fine with https and ASDM, cause they both require multiple authentication attempts to be send for different frames of the page and secure id will not allow this for the same token.
So I will suggest to create local TACACS account for authentication of ASDM.
~Rohit
