iBGP network problem, anyone know the solution ?
exam_toni888
R1---------------------------------R2-----------------------------------------R3---------------------------------------R4
10.10.10.1 /8 -- 10.10.10.2 /8 -- 172.172.172.2 /16 -- 172.172.172.3 /16 --192.168.1.3 /24 -- 192.168.1.4 /24
R1 in AS 100
R2,R3,R4 in AS 200
R2 and R4 already setup as non-direct neighbor
R1
router bgp 100
nei 10.10.10.2 remote-as 200
net 10.0.0.0
no auto-summary
R2
router bgp 200
no sync
nei 10.10.10.1 remote-as 100
nei 172.172.172.3 remote-as 200
nei 192.168.1.4 remote-as 200
net 10.0.0.0
net 172.172.0.0
no auto-summary
R3
router bgp 200
no sync
nei 172.172.172.2 remote-as 200
net 172.172.0.0
net 192.168.1.0
no auto-summary
R4
router bgp 200
no sync
nei 192.168.1.3 remote-as 200
net 192.168.1.0
no auto-summary
the question is:
routes in R1 show up in R4's BGP table, but why not in R4's routing table ?
but hey...sometime the R1's route appear in R4's routing table
and if we observe the bgp table sometime the route shows as best(>)
and then the best status gone
R4#h ip bgp
BGP table version is 29, local router ID is 192.168.1.4
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*>i10.0.0.0 172.172.172.2 0 100 0 i
*>i172.172.0.0 172.172.172.2 0 100 0 i
* i 192.168.1.3 0 100 0 i
* i192.168.1.0 192.168.1.3 0 100 0 i
*> 0.0.0.0 0 32768 i
R4#sh ip ro
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
B 172.172.0.0/16 [200/0] via 172.172.172.2, 00:00:56
B 10.0.0.0/8 [200/0] via 172.172.172.2, 00:00:56
C 192.168.1.0/24 is directly connected, Serial0/0
R4#sh ip bgp
BGP table version is 31, local router ID is 192.168.1.4
* i10.0.0.0 172.172.172.2 0 100 0 i
* i172.172.0.0 172.172.172.2 0 100 0 i
*>i 192.168.1.3 0 100 0 i
R4#sh ip ro
B 172.172.0.0/16 [200/0] via 192.168.1.3, 00:00:16
R4#
is this the normal behaviour ?
a.alekseev
Level 7
Level 7
BGP uses TCP
BGP based on IGP protocols such as EIGRP, OSPF, IS-IS
It's a good practice to use loopback interfaces for iBGP peering.
thank you, i'll try your suggestion i see what's the result,
but i still want to know the technical reasoning behind this issue.
rgds
Every bgp prefix have next-hop attribute.
For iBGP next-hop attribute must be know from IGP, not from iBGP.
