09-11-2007 08:57 AM - edited 03-14-2019 11:29 PM
I have E/Mobility working but on some occasions the logout option does not appear after logging in?
So after I press the services button on the phone - I see is this:
SERVICES
To set the speed dial and other services for you phone goto (192.168.x.x)
I have explicitly enabled logout service under the phone configuration sub/un-sub services?
I have found a way to do it. Goto device phone and press logout button. But this of course is not feasible solution. If I login to a phone then I should be able to logout - period.
tia
Ajaz
Solved! Go to Solution.
09-11-2007 09:10 AM
in the device profile you create for each EM user, you have to subscribe to the extension mobility service as you did per phone device.
this done you will will be able to logout after you have logged in.
by the way you can create two extension mobility services with names login and logout, repectively. with the same url but only names differ.
subscribe EM login per phone and and subscribe logout per device profile.
this will be meaningful for you IPT users.
hth
/majdi
09-11-2007 09:10 AM
hth
/majdi
09-12-2007 01:12 AM
thanks Majdi
Ajaz :-)
