Please Help: Multicast deployment in redundant campus LAN
May i know how you guys will setup the multicast for 2 pair of 6500s core switches?
Currently for my case is that each pair is connected with a trunk (layer 2) running HSRP to provide redundancy, then these 2 pairs are inter-connected (layer 3) together.
basically most of my end users are connected to access switches connecting to one pair trying to access the windows media server which is connected to another pair of core switches.
Would appreciate if you can share your configuration how i should setup the multicast config. thanks alot.
http://www.cisco.com/application/pdf/en/us/guest/tech/tk363/c1501/ccmigration_09186a008015e7cc.pdf
With regards to the design guideline provided, i have read and tested the small campus LAN deployment for my other sites, a question in my mind is:
1) is there a need for connectivity between the two loopback interfaces on both core switches? or are they only local significant? Because right now my Core1 is unable to ping to Core2 loopback0 interface which is normal as there isnt a layer 3 path presence to allow such connectivity.
interface Loopback0
description Interface used for RP/MA
ip address 1.1.1.1 255.255.255.255
ip pim sparse-dense-mode
interface Loopback0
ip address 1.1.1.2 255.255.255.255
2) For MSDP to works, there must be connectivity between the 2 loopback interfaces?
ybajpai Tue, 09/11/2007 - 12:43
without asking you the reason behind MSDP etc in your network, the short answer is that MSDP requires a tcp connection between the peers. So you do require connectivity between the loopbacks. optionally, you can specify any other interface as the MSDP originator/connect source id that does have connectivity to get ur MSDP session working between the two routers.
if these are not default peers then you also need bgp multicast afi configured.
Edison Ortiz Tue, 09/11/2007 - 17:48
On Question 1,
Based on the interface description, if those IPs are meant to be used as RP/MA - you must advertise them via a static or dynamic routing protocol.
Hi Edison,
So am i right to say i must put in a static route in Core1 that destine to the RP/MA interface in Core2 through reachable ip address of Core2 management IP?
Its seems that multicast still works even though these 2 interfaces are unreachable.
Can you also help on the 4 core design which is the earlier part of my question? Thanks
Edison Ortiz Wed, 09/12/2007 - 03:48
Multicast still works because you have interfaces running in sparse-dense mode. In the absence of a RP, the traffic will fall back to dense.
If you issue a 'show ip mroute' and see the flags on those routes, you will noticed you have "D" instead of "S".
As for the design, I'm hesitant to give you any recommendation without a formal analysis and this can take quite a bit of time.
Edison Ortiz Wed, 09/12/2007 - 07:27
The loopback address won't be shown on a 'show ip pim nei' command. The addresses shown on this output are the physical interfaces connected between the devices, if PIM is enabled.
Edison Ortiz Wed, 09/12/2007 - 19:34
The command you may be referring to is, 'show ip pim rp mapping'
Multicast may stress the CPU on the switch if it's process switched. How do you change the multicast from hardware switched (default) to software switched ?
1) entering 'no ip mroute-cache' on interfaces
2) placing ACLs against multicast flows
I'm sure there are others but those 2 are the most commons.
Hi Edison,
I'll disable mroute-cache on the interface then. By the way, how do we determine if it is hardware switched or software switched?
Anyway, for my small sites that i configured sparse-dense-mode, i have included static routes to point to individual loopback interfaces. but it seems it doesnt make any differences other then when i do a 'sh ip mcache' it shows some results from the peer core switch.
Can we communicate through email?
Remember initially whereby i said pinging to the loopback interfaces of the core switches is not possible?
I have include static route on both core switches so that both of them can ping each other's loopback interface.
It doesn't have any difference in multicast functionality even when its not pingable or pingable.
