7600 does not make CEF in HARD
Hi!
I configured 1 VRF in a 7600. I need to send some packets from the global table to that VRF. I configured 2 ports, one in the global table and the other in the VRF and join the 2 ports with a crossover cable. To send the traffic to the VRF i used a PBR. It works but
the traffic switched by de VRF is CEF in software, not in hardare. This configuration is supported in 7600?
Thanks in advance!!!
sultan-shaikh Tue, 01/08/2008 - 00:47
  • Bronze, 100 points or more
How have you confirmed that the packets are not switched in the hardware?
I use this command to check the same.
"show ip hardware-cef"
Also as you might know that for hardware CEF switching the module should have specific ASICs for do that job.
Cheers
