vlan
Answered Question
hi! What's the different between creating a vlan in a "vlan database" and global interface? + What's the different of configuring the vtp mode in the global interface and "vlan database"?
Correct Answer by szahid about 9 years 4 months ago
vlan database mode is being discontinued. There is however no difference between the 2 modes. Its just that configuring in global mode is now preferred.
Infact in most new codes , once you go to vlan database mode , it should give you a syslog that recommendation is to configure vlans / vtp in global mode.
salman.
Overall Rating: 5 (1 ratings)
Correct Answer
szahid Tue, 09/11/2007 - 10:23
salman.
