adding softkey back botton.
Sep 11th, 2007
How can I custumise the back Image or the softkey of the Phones (7911,7940,7970)?.
The one that appear when the phone is On Hook.
I need to create a new softkey bottom that point to my URL and a Image, if its possible at the back of the phone.
Thanks a lote!
ray
stephan.steiner Wed, 09/12/2007 - 00:25
  • Silver, 250 points or more
You want your own softkey in the idle screen of the phone? Then you need to write your own application and put it into the idle url of the phone so the phone will request it when it's idle. It is not possible to add your own custom softkeys to any standard screen of the phone - you can add certain telephony functions (look for softkey templates in ccmadmin), but it's not possible to have a softkey that launches an application.
