port scanner to check firewall acls
Jon Marshall Tue, 09/11/2007 - 17:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Mark
Nmap Security Scanner is one of the best there is and i have used it for the very same thing you are wanting to do.
Go to this page and download from there
www.nmap.org
Jon
ttrevino1 Wed, 09/26/2007 - 05:47
Hi Jon, regarding nmap, I just downloaded it the other day, and would also like to use the gui UMIT. Have you used this or had any luck installing it? I downloaded it, but keep getting an error when I try to open it.
Any help or direction would be appreciated.
