Changing time on AIP SSM 10 module.
Sep 11th, 2007
How can i change the sensors time manually on my AIP-SSM-10 module installed in the ASA 5520 device .. ??
i tried the clock set command but apparently its not supported on AIP-SSM-10 module.
the ASA has the correnct time but the IPS does not...
any ideas ??
tstanik Mon, 09/17/2007 - 12:44
AIP SSM can automatically synchronize its clock with the clock in the ASA in which it is installed. This is the default. The UTC time is synchronized between ASA and AIP SSM. The time zone and summertime settings are not synchronized between ASA and AIP SSM. You have to configure the time zone on the SSM because it is the UTC time that it gets from the ASA.
