C500 Switch
Sep 11th, 2007
I am facing some problem with the C500 switch.Switch port is hang imultaneously in between 3 to 4 hour.And after restart the switch its working some time and
again goes down.
I have system massages in that it shows me caused by MAC address 0201.0000.0000. on port fastethernet14.i didn?t understand where the exact problem.
htarra Mon, 09/17/2007 - 12:45
I think when you discover a device in the Discover Devices dialog box, the application sometimes displays the following dialog boxes as prompts:
Security Certificate
VPN Peer IP Address
Device Credentials
Sometimes, these dialog boxes disappear behind the Discover Devices dialog box, and the device discovery appears to hang.
Jagdeep Gambhir Mon, 09/17/2007 - 15:19
Make sure that you have 12.2.25 SEG running on the box , set up the right switch port role.
lalit0005 Tue, 09/18/2007 - 03:59
Box running on 12.2.25 SEG.and port role is Desktop.Still we face the same problem.I also check by replacing the switch but still problem is not solved.
