site-to-site international voice connectivity
Sep 11th, 2007
We would like to establish Voice connectivity to reduce calling cost between our two offices,one is in india and the other one is in dubai.
We have not yet able to decide a cost effective tentative initaial setup between dubai and india ,,A dedicated internet lease line wuold be better or is there any other option
I would appreciate your feedback about feasibility of this solution and experience to share.
spremkumar Wed, 09/12/2007 - 19:36
if you are more concerned on quality and clarity of the voice calls then i would suggest to go for IPLC instead of internt pipe.
You may not have proper SLA's for ILL when compared to IPLC.
Since its a P2P (IPLC) you can workaround on the code and end point devices also on both the ends.
Gives you more options in choosing your equipments and other related settings.
ciscodegama Fri, 09/14/2007 - 21:28
Thanks a lot sir
Can u suggest me how much bandwidht is required for International voice calls?
spremkumar Thu, 09/20/2007 - 04:06
AFAIK it depends on the codec which you are going to use and also the end point devices used at both the ends.
you can think off using some compression techniques also to use the bandwidth more efficiently.
