BRI Connection
Sep 12th, 2007
hi,
I am trying to connect a 2821 router with NM−4B−S/T to 2811 router with NM−4B−U.
I installed the cards, made a crossover ISDN cable (3-6,4-5) and connected each other.
but there is no light, nothing.
Please help.
lgijssel Wed, 09/12/2007 - 00:18
  • Red, 2250 points or more
This setup will not work. You are going to need an ISDN switch in between.
regards,
Leo
okanyilmaz Wed, 09/12/2007 - 01:06
what is an isdn switch?
Can i use a router instead?
lgijssel Wed, 09/12/2007 - 01:26
An ISDN switch is what a telephony provider uses to provide ISDN lines. I suppose that you have non of these around.
A router will not help you further, you could hook up both routers to an ISDN line if you have one. Even better would be to use two separate ISDN lines.
Leo
