restore wizard 5.1
Sep 12th, 2007
Hi Guis,
I'm tring to restore a backup.tar file generated by DMA, But i encounter a problem, the restore wizard do not find a .tar file but i have configured properly the sftp.
In the path name i have put /
in the sftp the root directory is c:\DMABACKUP\
and the name of the backup is DMABackup07-24-07.tar
There are some tips to configure this ?
Any information is appreciate.
Overall Rating: 4 (1 ratings)
mchandak Wed, 09/12/2007 - 05:47
  • Gold, 750 points or more
Are you trying to restore this during the install of CM 5.1 or trying to use this with an already installed box. DMA is used during the install of the server and cannot be used as a backup restore. when doing a restore, you should use backup created using DRS.
Also, what is the SFTP server you are using ?
