Easy VPN with mutiple outside interfaces
Sep 12th, 2007
Hi, I'm trying to do a VPN configuration with easy VPN (between two IOS router, ver 12.4(11)T2). The central router has one Internet connection. The remote router has 2 Internet connection (to provide more bandwidth - ADSL). When I try to the feature "multiple outside interface" I get an error:
R2R(config)#int eth 1/0
R2R(config-if)#crypto ipsec client ezvpn LFR-CLI outside
R2R(config-if)#int eth 1/1
Error:Only one outside interface is allowed per ezvpn configuration
Best Regrads
abuladzesergo Mon, 09/14/2015 - 01:59
I have same problem.
I try to do one vpn connection throught 2 internet connections to one EasyVPN server.
If I try to do second vpn with same config - it writes that "Vlan1 cannot be part of two easy VPN Remote configs."
If I try to add same config to other wan interface - it writes: "Only one outside interface is allowed per ezvpn configuration."
