Problem uploading IOS to Cisco 3560
Sep 12th, 2007
Hi, I have sent an IOS file called c3560-ipbasek9-mz.122-40.SE.bin (IP Base version) to by Cisco Catalyst 3560 switch by running:
copy tftp://1.2.3.4/c3560-ipbasek9-mz.122-40.SE.bin flash:
It successfully copies it, but if i reboot and type show version I still get the old version?
Any ideas?
royalblues Wed, 09/12/2007 - 04:45
  • Green, 3000 points or more
Chnage the boot system parameter
(config)#boot system flash:c3560-ipbasek9-mz.122-40.SE.bin
you can verify it via the sh boot command
HTH, rate if it does
Narayan
whiteford Wed, 09/12/2007 - 05:44
Think it worked does this look ok, the bootstrap is still old:
Backup_Network>sh version
Cisco IOS Software, C3560 Software (C3560-IPBASEK9-M), Version 12.2(40)SE, REL
SE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 24-Aug-07 01:38 by myl
Image text-base: 0x00003000, data-base: 0x01500000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SE1, RELEASE SOFTW
E (fc)
Backup_Network uptime is 7 minutes
System image file is "flash:c3560-ipbasek9-mz.122-40.SE/c3560-ipbasek9-mz.122-
.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C3560G-24TS (PowerPC405) processor (revision C0) with 122880K/8184K b
es of memory.
Processor board ID FOC0924U2JW
Last reset from power-on
1 Virtual Ethernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:14:A8:2E:70:00
Motherboard assembly number : 73-9708-04
Power supply part number : 341-0098-01
Motherboard serial number : FOC09245CSX
Power supply serial number : DCA09210H8N
Model revision number : C0
Motherboard revision number : A0
Model number : WS-C3560G-24TS-S
System serial number : FOC0924U2JW
SFP Module assembly part number : 73-7757-03
SFP Module revision Number : A0
SFP Module serial number : CAT09220RBC
Top Assembly Part Number : 800-25864-02
Top Assembly Revision Number : A0
Version ID : 02
CLEI Code Number : CNMW200ARB
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 1 28 WS-C3560G-24TS 12.2(40)SE C3560-IPBASEK9-M
royalblues Wed, 09/12/2007 - 05:50
Yes this looks good.
Chnaging the IOS will not chnage the bootstrap though but that should not be worry
Narayan
lgijssel Wed, 09/12/2007 - 04:53
  • Red, 2250 points or more
Perform the upgrade by using a combined tar file. This file contains both the Cisco IOS image file and the files needed for CMS. You must use the combined tar file to upgrade the switch through CMS. To upgrade the switch through the command-line interface (CLI), use the tar file and the archive download-sw privileged EXEC command.
regards,
Leo
lgijssel Wed, 09/12/2007 - 04:57
You may not have the required rights on CCO.
Perhaps you can ask your distributor or a collegue for the correct file?
whiteford Wed, 09/12/2007 - 04:59
Can you find the link if possible? I can then see if my username and password let me, I can download most things on our Smartnet contract.
whiteford Wed, 09/12/2007 - 05:10
Which one should I try:
IP BASE W/O CRYPTO WITH WEB BASED DEV MGR
c3560-ipbase-tar.122-40.SE.tar
Release Date: 28/Aug/2007
Minimum Memory: DRAM:128MB Flash:16MB
or
IP BASE WITH WEB BASED DEV MGR
c3560-ipbasek9-tar.122-40.SE.tar
there are others too.
royalblues Wed, 09/12/2007 - 05:14
The second one is a crypto graphic image and would alow you to configure features like SSH etc..
You can choose anyone as long as it fulfils your requirements
Narayan
