PPTP Server on a 1801 with adv sec
Sep 12th, 2007
Hi, I have an 1801 with advanced security running on a site with a l2l ipsec vpn tunnel. Everything is working fine. I need to be able to terminate pptp vpns (Microsoft vpn client) on the router. can this be done. I would imagine I have to allow port 1723 and gre in on the main acl and also set up the pptp server on the router. Any help or config examples would be great. Attached there is a cut down config.
regards,
Ciaran
Overall Rating: 5 (1 ratings)
umedryk Tue, 09/18/2007 - 06:08
  • Bronze, 100 points or more
PNS which is called as PPTP Network Server is the Device that is able to terminate PPTP tunnels from a PAC and terminate PPP sessions to remote systems through PPTP data sessions.
JPDisney01 Mon, 01/07/2008 - 07:19
NAT'ng GRE requires its own external IP as GRE is IP 47 (not TCP/UDP). Not sure how this would work with the router acting as the terminating device rather than a server though...
