How to I set a users permission on a 3750 for READ-ONLY
Sep 12th, 2007
All, I am wanting to set the permissions on a 3750 so that once a user logs into the switch, all they can do is issue show commands and ping devices? I want to do this only from this switch. I do not have AAA and I do not have a radius box. Much appreciated.
Overall Rating: 5 (1 ratings)
royalblues Wed, 09/12/2007 - 04:50
  • Green, 3000 points or more
Configure the username with a privilege level of 1 and define the commands that can be used in that privilege level
username xxxx privilege 1 secre yyyyy
privilege line level 1
Narayan
lgijssel Wed, 09/12/2007 - 04:51
  • Red, 2250 points or more
Accessing a device via telnet brings you in this mode by default.
Simply keep the enable secret for yourself.
regards,
Leo
rwamstutz Wed, 09/12/2007 - 04:58
thank you. Is it possible to have read-only on the web-access portion?
Jagdeep Gambhir Wed, 09/12/2007 - 05:03
I don't think so. To access Http users requires priv 15.
~JG
