auth fail 7911/06 load sccp41.8-3-1-s
Sep 12th, 2007
i install load sccp41.8-3-1-s. may 7941/61 are ok but the 7911/06 make boot error. auth fail. after the boot continu. I want how to make boot correctly.
I dont have error with load SCCP11.8-2-1S. just with load SCCP11.8-3-1S and SCCP11.8-3-2S
rafael.cardoso Fri, 09/14/2007 - 08:06
it lacked you to point the archive of loads in the Callmanager:
Device Settings >
Firmware Load Information >
Device Defaults Configuration >
Cisco 7911 = SCCP11.8-3-1S
good luck
rafael.cardoso Fri, 09/14/2007 - 08:19
You dont have error with load SCCP11.8-2-1S. Because all the archives of the package are complete. Go ties the site of the Cisco in Downlods software searching the image: cmterm-7911_7906-sccp.8-3-2SR1.exe - it could be found after executed in the way: C:\Program Files\Cisco\TFTPPath - in Server.
