Problems with Bat with Excell 2007
Sep 12th, 2007
Has anyone run into problems with latest bat.xls and Excell 2007? The create file format is greyed out so unable to use. I have latest BAT installed on CCM and took bat.xls from CCM.
thanks
Overall Rating: 5 (1 ratings)
a.gooding Thu, 09/13/2007 - 18:33
  • Bronze, 100 points or more
You have to enable macros for the buttons to work
Click on the office button and click excel options. then go to trust centre and trust center settings. go to macro settings and enable. close off the program and reopen and that should do it.
