T37 fax onramp question
Sep 12th, 2007
Hi!
I have a CM,GW and exchange server(no unity). I am trying to get the fax onramp to work. Where do I specify which mailbox the incoming fax will hit, is this done in GW or Exchange. My thought was that you tied all the fax-ext with the email-accounts in the GW. I think I am lost on this one, every reply would be very much appreciated.
Mattias
teodorgeorgiev Fri, 09/14/2007 - 00:27
Mattias,
these settings have to be configured on the Cisco gateway that is actually doing the T.37.
Here is some example config:
mta send server 10.10.10.1 port 25
mta send subject Fax has been received !!!
mta send postmaster [email protected]
mta send mail-from hostname cisco-gw.test.com
mta send mail-from username $s$
mta receive aliases test.org
mta receive aliases test.net
mta receive maximum-recipients 20
