CUPC & CCM5.1.2 but NO CUPS
Sep 12th, 2007
Hi All,
I have a CCM5.1.2 Cluster without CUPS. I am wanting to use CUPC on desktops for call control etc...
The issue is authentication see below:
2007-09-12 14:28:38,846 [0x120] DEBUG LCMiddleware - Service::Start() - Service[ConfigurationManager], currentState[SERVICESTATE_OFFLINE]
2007-09-12 14:28:38,846 [0x120] INFO LCWIN32UI - (WINUI_LOGIN_DIALOG_ONCLOSE) Login Dialog 0x1e86420 is closing
2007-09-12 14:28:38,846 [0x4a4] DEBUG LCMiddleware - Service::StartupThread() - Service[ConfigurationManager], currentState[SERVICESTATE_OFFLINE]
2007-09-12 14:28:38,846 [0x4a4] DEBUG LCMiddleware - Service::StartupThread - Starting Service [ConfigurationManager] uid[7]
2007-09-12 14:28:38,846 [0x4a4] DEBUG LCMiddleware - ConfigurationManager::StartProc()
2007-09-12 14:28:38,846 [0x4a4] INFO LCMiddleware - (MWMSG_EIM_ADDINGLISTENERS) Adding all EPASInterfaceManager listeners
2007-09-12 14:28:38,846 [0x4a4] DEBUG LCMiddleware - Service::Start() - Service[EPASInterfaceManager], currentState[SERVICESTATE_OFFLINE]
2007-09-12 14:28:38,846 [0x4b4] DEBUG LCMiddleware - TimerManager::TimerThread started
2007-09-12 14:28:38,846 [0x4bc] DEBUG LCMiddleware - Service::StartupThread() - Service[EPASInterfaceManager], currentState[SERVICESTATE_OFFLINE]
2007-09-12 14:28:38,846 [0x4bc] DEBUG LCMiddleware - Service::StartupThread - Starting Service [EPASInterfaceManager] uid[8]
2007-09-12 14:28:38,846 [0x4bc] DEBUG LCConnection - ConnectionManager: REGISTER CONNECTION: ConnectionType: CUPS_CONFIG, server list: primary=10.44.10.3:443(https), backups=
retry timer: EXPONENTIAL : minWait=500(ms), maxWait=64000(ms), maxRetries=0, totalRetries=0, retryInterval=500(ms)
failover timer: EXPONENTIAL : minWait=500(ms), maxWait=64000(ms), maxRetries=0, totalRetries=0, retryInterval=500(ms)
failback timer: EXPONENTIAL : minWait=500(ms), maxWait=64000(ms), maxRetries=0, totalRetries=0, retryInterval=500(ms)
failback policy: ROUND_ROBIN
2007-09-12 14:28:38,862 [0x4bc] DEBUG LCConnection - CUPS_CONFIG startConnection(): 10.44.10.3:443(https)
2007-09-12 14:28:38,862 [0x4bc] DEBUG LCConnection - CUPS_CONFIG setState(): [IDLE] --> [CONNECTING_PRIMARY]
2007-09-12 14:28:39,784 [0x4bc] ERROR LCMiddleware - (MWMSG_EIM_SOAPLOGINFAILED) Failed to log in to SOAP server https://10.44.10.3/EPASSoap/service, Host unreachable
2007-09-12 14:28:39,784 [0x4bc] DEBUG LCConnection - CUPS_CONFIG setReason(): [NONE] --> [UNREACHABLE]
2007-09-12 14:28:39,784 [0x4bc] ERROR LCMiddleware - (MWMSG_CFGMGR_EPASSERVICEERR) ConfigurationManager::Update_ServiceError() - CUPS service error [1]
2007-09-12 14:28:39,784 [0x120] ERROR LCWIN32UI - (WINUI_ERROR_SERVICE_ERROR) ******** CONFIG MANAGER ERROR [1] **************
2007-09-12 14:28:39,784 [0x4bc] DEBUG LCConnection - CUPS_CONFIG setState(): [CONNECTING_PRIMARY] --> [ERROR]
2007-09-12 14:28:39,784 [0x4a4] ERROR LCMiddleware - (MWMSG_SERVICELIST_WAITABORTED) ServiceConditions::Wait(4) - ABORTED
2007-09-12 14:28:39,784 [0x4a4] DEBUG LCMiddleware - ConfigurationManager::AbortProc() - condition[4]
2007-09-12 14:28:39,784 [0x4a4] INFO LCMiddleware - (MWMSG_EIM_REMOVINGLISTENERS) Removing all EPASInterfaceManager listeners
2007-09-12 14:28:39,877 [0x120] INFO LCWIN32UI - (WINUI_LOGIN_DIALOG_OPENING) Login Dialog 0x1e7ae88 is opening
2007-09-12 14:28:41,299 [0x120] INFO LCWIN32UI - (WINUI_LOGIN_DIALOG_ONCLOSE) Login Dialog 0x1e7ae88 is closing
Any help would be beneficial..
Many Thanks
Montagu.IT Thu, 09/13/2007 - 08:13
Chris,
There is no CUPS Server.
Its a straight 5.1.2 Cluster and nothing else.
Surely CUPC can work without a CUPS Server???
